[GRASSLIST:1183] Re: Recompiling
Daniel Lau iedaniel at ust.hk
Wed Sep 10 23:11:57 EDT 2003
Hi all,
I am trying to change the code of a single module. Recompling takes me 10
minutes. How to recompile just one module and put it in the suitable
directory manually or automatically?
The procedures I am using is:
/grass5.0/src/display/src/gmake5
/grass5.0/make install
Daniel
On Wed, 10 Sep 2003, Glynn Clements wrote:
> Bill Dickinson Jr wrote:
> > > Source install:
> > > Try compiling without the --with-readline ./configure option, it
> > > isn't critical, I think.
> > Are there any pitfalls when recompiling GRASS? Do I simply run the
> > configure/make/make install again? Does this overwrite the current
> > installation or do I have to clean out the current installation
> > before recompiling?
> If you re-run configure, run "make distclean" before recompiling.
> "make install" should just overwrite any existing installation,
> although it's probably worth removing the old installation prior to
> running "make install" just to be safe.
> Glynn Clements <glynn.clements at virgin.net>
