[GRASSLIST:1187] Re: 5.1 under Cygwin
Markus Neteler
neteler at itc.it
Thu Sep 11 04:16:02 EDT 2003
On Wed, Sep 10, 2003 at 09:42:21AM +0100, Paul Kelly wrote:
> Hello
> On Tue, 9 Sep 2003, Richard Greenwood wrote:
> > 3. Has anyone successfully compiled 5.1 under Cygwin?
> I have compiled most of it recently (and made some changes to the
> Makefiles to enable it to compile). You need to use the --enable-shared=no
> option to the configure script, as you can't compile conventional Unix
> shared libraries in Cygwin.
I have stored a script which runs 'configure' under Cygwin here:
http://grass.itc.it/grass51/source/conf_scripts/cygwin_xserver/
conf_grass51_cygwin.sh
Perhaps you could try it, and, if needed, post updates to this script?
> NVIZ wouldn't compile, I think probably because of the recent changes
> which use some non-standard OpenGL features and glX functions etc. (which
> should probably get fixed before the 5.3.0 release). I think there was a
> problem with some imagery modules as well that I didn't fix yet. But you can
> just delete the visualization and imagery directories from the main Makefile
> to jump over these errors.
Please post them on 'grass5' so that we can try to fix them.
Thanks,
Markus
