[GRASSLIST:1155] Re: 5.1 under Cygwin
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Sep 10 04:42:21 EDT 2003
Hello
On Tue, 9 Sep 2003, Richard Greenwood wrote:
> 3. Has anyone successfully compiled 5.1 under Cygwin?
I have compiled most of it recently (and made some changes to the
Makefiles to enable it to compile). You need to use the --enable-shared=no
option to the configure script, as you can't compile conventional Unix
shared libraries in Cygwin.
NVIZ wouldn't compile, I think probably because of the recent changes
which use some non-standard OpenGL features and glX functions etc. (which
should probably get fixed before the 5.3.0 release). I think there was a
problem with some imagery modules as well that I didn't fix yet. But you can
just delete the visualization and imagery directories from the main Makefile
to jump over these errors.
Paul
