[GRASSLIST:1214] tcltkgrass crash on startup
David Orme d.orme at imperial.ac.uk
Fri Sep 12 12:27:22 EDT 2003
I'm getting this when I try and start up tcltkgrass from within grass
5.0.2 running on Mac OS 10.2.6:
> GRASS 5.0.2 > tcltkgrass &
> [1] 869
> Mapset <dorme> in Location <global-latlong>
> GRASS 5.0.2 > Error in startup script: xwininfo: error: No such window
> with id 0x1847188.
>     while executing
> "exec xwininfo -id [winfo id .w_g] | grep -i Corners"
>     invoked from within
> "scan [exec xwininfo -id [winfo id .w_g] | grep -i Corners] {%*s %d%d}
> dx dy"
>     (file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1887)
>     invoked from within
> "source $env(TCLTKGRASSBASE)/main/gui.tcl"
>     (file "/usr/local/grass5/bin/tcltkgrass" line 21)
> [1]    Exit 1                        tcltkgrass
> GRASS 5.0.2 >
It previously worked fine - I'm fairly sure (but not certain - I mostly
use command line) that it worked directly after I upgraded to 5.0.2.
Any suggestions? My suspicion is an environmental variable so I've
appended the output on printenv in case anyone can spot something
suspicious.
Thanks in advance.
David
GRASS 5.0.2 > printenv
PWD=/Users/dorme
WINDOWID=4194318
LD_LIBRARY_PATH=/usr/local/grass5/lib
GRASS_GUI=text
GISBASE=/usr/local/grass5
USER=dorme
GISRC=/Users/dorme/.grassrc5
LANG=en_US
GIS_LOCK=688
GRASS_WISH=wish
DISPLAY=:0.0
SHLVL=3
LOGNAME=dorme
GRASS_PAGER=less
SHELL=/bin/tcsh
HOME=/Users/dorme
TERM=xterm
GRASS_TCLSH=tclsh
PATH=/usr/local/grass5/bin:/usr/local/grass5/scripts:/usr/bin:/bin:/
usr/sbin:/sbin:/Users/dorme:/usr/X11R6/bin
__CF_USER_TEXT_ENCODING=0x1F5:0:0
GRASS_GNUPLOT=gnuplot -persist
GRASS_PERL=PERL_COMMAND
_=/usr/local/grass5/etc/run
HOSTTYPE=macintosh
VENDOR=apple
OSTYPE=darwin
MACHTYPE=powerpc
GROUP=staff
HOST=doibook.bio.ic.ac.uk
Dr. David Orme
Department of Biological Sciences
Imperial College London
Silwood Park Campus
Ascot, Berkshire SL5 7PY UK.
Tel: +44 (0)20 759 42358
Fax: +44 (0)20 759 42339
e-mail: d.orme at imperial.ac.uk
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030912/902caeee/attachment.bin
