[GRASSLIST:1228] Re: install GDAL & import Landsat7 ETM+ xxx...xxx...bx0.l1g File (HDF)
Andrey Kiselev dron at ak4719.spb.edu
Sat Sep 13 15:55:37 EDT 2003
On Sat, Sep 13, 2003 at 05:09:24PM +0900, Alip.Yasin wrote:
> And after that I tried to import Landsat7 ETM+
> l71146029_02920010925_b10.l1g,
> using r.in.gdal command.
> And it's said that [ Error 4, not recognized as a supported file ].
> But I learned that GDAL can handle with HDF.
> So I wonder why I could't import Landsat7 etm+ into GRASS.
> Is my data which named  l71146029_02920010925_b10.l1g was not a HDF,
> because, I thought, the extensions was '"l1g" not "hdf".
> How could I inroduce the "xxx...xxx...xxx.l1g" into GRASS?
> (my installed GDAL verstion was gdal1.1.9)
Your Lansat is probably in FAST format. To read FAST dataset using GDAL
you should give to r.in.gdal name of the header file. Read here for more
information:
 http://www.remotesensing.org/gdal/frmt_fast.html
 						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
