[GRASSLIST:1285] Re: cygwin compile gd.h not found
Richard Greenwood
Rich at GreenwoodMap.com
Thu Sep 18 09:54:51 EDT 2003
Glynn, et al;
Apologies for my dumb question. I was using a configure script as a
template and adding my switches at the beginning of the list. I disabled GD
at the beginning of the list, but there was a --with-gd=yes further down in
the list.
Thank you for your help, sorry to waste your time.
Rich
At 05:04 AM 9/18/2003 +0100, you wrote:
>Richard Greenwood wrote:
> > > > I am trying to compile 5.0.2 under cygwin. Congigure fails while
> > > > checking for location of GD includes: gd.h not found. Even if I
> > > > configure with-gd=no.
> > > > Any suggestion?
> > >Did you spell the option correctly? There should be two leading
> > >dashes, i.e. "--with-gd=no" or "--without-gd".
> > Yes, I've tried both options, which result in the same problem.
> > Interestingly, the configure says:
> > checking whether to use GD... yes
> > checking for location of GD includes...
> > checking for gd.h... no
>Does this only apply to --without-gd, or to all of the
>--without-options?
> > Is it possible that I have some dependency that is causing this?
>No; the --with-* options are never enabled or disabled automatically
>by the configure tests.
>Glynn Clements <glynn.clements at virgin.net>
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
