[GRASSLIST:1305] Re: importing soil sediment data
Helmer Schack-Kirchner helmer.schack-kirchner at bodenkunde.uni-freiburg.de
Fri Sep 19 08:04:20 EDT 2003
To import the data rearrange it to the format described in
the command 's.in.ascii'. (long lat #cat %dec
.... at string...) For this purpose you may use a spread sheet
program, a column orientated text editor or, the best
solution an awk program.
With s.in.ascii you produce a site file, where all
attributes can be analysed with grass functionality. For
analysis you may interpolate to raster files or  calculate
indices with r.mapcalc ...
Best regards,
Helmer
 Hi all
>    I had scanned a hand drawn contour map (of sea bottom)
> and
> georeferenced it and converted into a raster DEM in
> GRASS. now i have soil composition data for that area and
> the data is taken from discrete locations.
> well the file is some what in the foll. format having
> foll. fields separated by space
> "station No"  "Lon"  "Lat"  "sand%"  "silt%"  "clay%"
>  "Classification"
> well eg. data is as follows
> "sk\175\72" 15.504833 96.671833 0.007707 45.507093
> 54.4852 "Silty clay"
> "sk\175\56" 15.003 96.250833 0.009301 47.359939 52.63076
> "Silty clay"
> "sk\175\50" 15.2475 96.994167 0.014721 43.232689 56.75259
> "Silty clay"
> "sk\175\129" 12.04167 96.499 9.509982 49.775198 40.71482
> "Clayey Silt"
> "sk\175\108" 13.750667 97.7521 9.733366 46.020 44.24608
> "Clayey Silt"
> "sk\175\122" 12.504833 97.002667 94.06022 0.190377
> 5.749402 "Sand"
> "sk\175\102" 13.997833 96.500833 94.18088 1.722768
> 4.096352 "Sand"
> how can i import this data into grass ???
> can i import this as a site data.
> I want to display it over the raster bathymetry generated
> as above.
> and please could any one tell me what possible analysis
> can i do with it.
> actually i am new to grass and actually trying out things
> so that we can determing how useful grass can be to our
> department.
> Thanking All in Advance
> --Amit--
> Amit Keney
> Information Technology Group
> National Institute of Oceanography
> Goa.
> Ph. 2450213
