[GRASSLIST:1309] Re: importing .e00 files
Michel Wurtz
mjwurtz at wanadoo.fr
Fri Sep 19 18:48:50 EDT 2003
Kirk R. Wythers wrote:
> I just tried importing a dem with the command:
> m.in.e00 -s name_of_file.e00
> Now I would like to display the vector map. I assumed that the mapname
> would be name_off_file (without the .e00 extension. However, when I try
> and use:
> d.vect name_of_file, I get the folowing error:
> ERROR: Vector file [dem25imn] not available
> what's up?
If the .e00 file contains a dem, it is probably an ESRI grid, hence a
raster file. In this case, m.in.e00 produce also a raster as output.
Try d.rast dem25imn, it should work.
Michel Wurtz - Auzeville-Tolosane
