[GRASSLIST:1323] Re: datum transformation and r.proj
Luis Coronado guaiacum at racsa.co.cr
Mon Sep 22 01:54:17 EDT 2003
I am currently using CVS HEAD from GRASS CVS, but when I write g.version
at the console I get:
GRASS 5.0.3-cvs (April 2003)
I compiled this working installation a couple of days ago and I usually
update my sources every couple of days.
So even though I know I'm using  5.3, why do I get 5.0.3? Just asking, I
don't mind some numbers being wrong here and there :).
Regards
Luis Coronado
Costa Rica
On Sat, 2003-09-20 at 15:35, Glynn Clements wrote:
> JDougherty wrote:
> > > > I need to reproject raster data to a different ellipsoid. Is
> > > > this already supported in version 5.0.2 as the r.proj help in
> > > > the online 5.0.x manual pages says, or do I need version 5.3?
> > > You need version >= 5.3 (CVS HEAD or snapshots) (the online
> > > manual pages corresond to the 5.3.x CVS HEAD)
> > A question, 5.3, or 5.0.3?
> 5.3.
> There are now 3 branches:
> 5.0 (CVS repository "grass", branch "releasebranch_26_april_2002_5_0_0").
> 5.3 (CVS repository "grass", HEAD).
> 5.7 (CVS repository "grass51", HEAD).
> 5.0 is the stable branch, from which the various 5.0.x releases are
> derived. Future releases from this branch should contain only
> bug-fixes or minor, backward-compatible improvements. FWIW, 5.0.3
> should be released quite soon.
> 5.3 is the development version of 5.0. It will include anything which
> is added to the 5.0 branch (although such changes will typically go
> into 5.3 initially, then get merged into the 5.0 branch later), plus
> some other changes which are too intrusive to go into the 5.3.x
> releases (e.g. because they break backwards compatibility, or
> introduce additional dependencies).
> 5.7 is the experimental version which was previously referred to as
> "5.1". As it is unlikely that this version will become sufficiently
> stable to obsolete 5.0.x in the forseeable future (i.e. the next
> couple of years), it was renamed to 5.7 to allow for at least two
> more complete stable releases (i.e. 5.4 and 5.6).
