[GRASSLIST:1348] Re: compiling on RedHat and Gmakefile error
Glynn Clements glynn.clements at virgin.net
Wed Sep 24 17:50:27 EDT 2003
Javier Álvarez Rodríguez wrote:
> I wonder if someone can help us with our GRASS compilation on RedHat Linux.
> The problem is that after running ./configure with option –without-fftw,
> make and make install, we can not go on with /usr/local/bin/gmake5 because
> Gmakefile is not found. What did I do wrong?. Any clue?
What exactly are you trying to do? You don't need to use "gmake5" when
compiling and installing GRASS normally; it's only required if you
wish to subsequently compile (or re-compile) specific parts of GRASS.
Glynn Clements <glynn.clements at virgin.net>
