[GRASSLIST:3160] Re: error whit vector
Markus Neteler neteler at itc.it
Wed Apr 14 04:47:38 EDT 2004
Please run
v.build map=AP_nazionali_aprile03_region
and retry. Perhaps the topology file is not up-to-date.
Markus
On Tue, Apr 13, 2004 at 05:22:56PM +0000, Daniele Scarselli wrote:
> Hi all,
> we have seen that if we import a vector with a version of GRASS 5.7 we
> cannot display it with different  snapshots of GRASS.
> the output message is the following:
> child killed: segmentation violation
>    while executing
> "exec d.vect map=AP_nazionali_aprile03_region at PERMANENT color=0:0:0
> lcolor=0:0:0 fcolor=170:170:170 display=shape
> type=point,line,boundary,centroid,are..."
>    ("eval" body line 1)
>    invoked from within
> "eval "exec $cmd >@stdout 2>@stdout""
>    (procedure "Dm::execute" line 12)
>    invoked from within
> "Dm::execute $cmd"
>    (procedure "DmVector::display" line 75)
>    invoked from within
> "DmVector::display $node"
>    ("vector" arm line 2)
>    invoked from within
> "switch $type {
>        group {
>            DmGroup::display $node
>    raster {
>        DmRaster::display $node
>    labels {
>        DmLabels::display $node
>    (procedure "Dm::display_node" line 6)
>    invoked from within
> "Dm::display_node $n"
>    (procedure "DmGroup::display" line 11)
>    invoked from within
> "DmGroup::display "root""
>    (procedure "Dm::display" line 5)
>    invoked from within
> "Dm::display"
>    ("uplevel" body line 1)
>    invoked from within
> "uplevel \#0 $cmd"
>    (procedure "Button::_release" line 18)
>    invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
>    (command bound to event)
> Is this a bug or an our error?
> Thank you a lot
> Daniele & Leonardo
