[GRASSLIST:3181] gmake53 problem
Massimiliano Cannata massimiliano.cannata at supsi.ch
Thu Apr 15 08:54:28 EDT 2004
Hello, I have a problem compiling new commands.
When I try to run "gmake53 -i" i get the following error:
[root at maxi Interception]# /usr/local/bin/gmake53 -i
  SRC     = /home/mcannata/grass53_exp_2004_03_27/src
  CMD     = /home/mcannata/grass53_exp_2004_03_27/src/CMD
  UNUSED  = /home/mcannata/grass53_exp_2004_03_27/unused
  HEADER  = head.i686-pc-linux-gnu
  ARCH    = i686-pc-linux-gnu
  GISBASE = /home/mcannata/grass53_exp_2004_03_27/dist.i686-pc-linux-gnu
  VERSION = 5.3-cvs 2004
/home/mcannata/grass53_exp_2004_03_27/ModelloIST/Interception
  make -f OBJ.i686-pc-linux-gnu/make.rules
make:
`/home/mcannata/grass53_exp_2004_03_27/dist.i686-pc-linux-gnu/etc/bin/cmd/r.interception'
is up to date.  make -f OBJ.i686-pc-linux-gnu/make2.rules
gcc
-L/home/mcannata/grass53_exp_2004_03_27/src/libes/LIB.i686-pc-linux-gnu
-Wl,--export-dynamic -o /etc/bin/cmd/r.interception
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/functions.o -lgis
-lm  -lz
/usr/bin/ld: cannot open output file /etc/bin/cmd/r.interception: No
such file or directory
collect2: ld returned 1 exit status
make: *** [/etc/bin/cmd/r.interception] Error 1
Why does it try to make it in /etc/bin/cmd/r.interception ? The new code
are in the current directory:
I have installed grass53 with the options --prefix=/home/grass  and
--bindir=/home
Suggestions?????
Thanks again.
note: change my e-mail reference to massimiliano.cannata at supsi.ch
      because the old one will be deleted soon.
Ing.  Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040415/ad2ec108/attachment.html
