[GRASSLIST:3182] Re: gmake53 problem
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Apr 15 09:27:52 EDT 2004
On Thu, 15 Apr 2004, Massimiliano Cannata wrote:
> Hello, I have a problem compiling new commands.
> When I try to run "gmake53 -i" i get the following error:
> [root at maxi Interception]# /usr/local/bin/gmake53 -i
> I have installed grass53 with the options --prefix=/home/grass and
> --bindir=/home
> Suggestions?????
Just one idea but if bindir is /home should you not be running
/home/gmake53 rather than /usr/local/bin/gmake53?
Have you run make through to its completion (or the gmake53 script won't
have been created properly)?
You also could try using the alternate build mechanism (./configure
--enable-gmake=no) which might be better.
Paul.
