[GRASSLIST:3184] Re: gmake53 problem
Massimiliano Cannata massimiliano.cannata at supsi.ch
Thu Apr 15 11:21:00 EDT 2004
sorry, i run
ln -s /home/bin/gmake53 /usr/local/bin/gmake53
but also using  /home/bin/gmake53 the output is always the same......
running:
- cd to my code directory
- gmake53
- gmakelinks53
- cd to my root_of_grass_source
- make install
Now i can have my new command in grass, but it is not really smart.....
other suggestion?
Paul Kelly wrote:
>On Thu, 15 Apr 2004, Massimiliano Cannata wrote:
>>Hello, I have a problem compiling new commands.
>>When I try to run "gmake53 -i" i get the following error:
>>[root at maxi Interception]# /usr/local/bin/gmake53 -i
>>I have installed grass53 with the options --prefix=/home/grass  and
>>--bindir=/home
>>Suggestions?????
>Just one idea but if bindir is /home should you not be running
>/home/gmake53 rather than /usr/local/bin/gmake53?
>Have you run make through to its completion (or the gmake53 script won't
>have been created properly)?
>You also could try using the alternate build mechanism (./configure
>--enable-gmake=no) which might be better.
>Paul.
note: change my e-mail reference to massimiliano.cannata at supsi.ch
      because the old one will be deleted soon.
Ing.  Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040415/bdc5c86e/attachment.html
