[GRASSLIST:3191] Re: gmake53 problem
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Fri Apr 16 06:14:20 EDT 2004
I have tryed to recompile everything, so here is my runs:
* make distclean
* find / -name gmake53
* i remove all the gmake53, gmakelinks53 and grass53
* configure with:
CFLAGS="-O3 -mcpu=pentium -Wall" ./configure --prefix=/home/grass
--with-postgres-includes=/usr/include/pgsql/server/ --with-motif
--with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include/
--with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib/ --with-blas
--with-lapack --with-glw --with-dbm
--with-dbm-includes=/usr/include/gdbm --with-freetype
--with-freetype-includes=/usr/include/freetype2/
--without-readline --with-fftw --with-proj
--with-proj-libs=/usr/local/lib --with-cxx
* make
* make install
Now I get a my grass running correctly with all the commands, i also
have a new /home/grass/bin directory with gmake53, gmakelinks53 and
grass53 files just created (those shold be the rigth ones).
Unfortunately when i try to compile my new code it continues to give the
same error:
/usr/bin/ld: cannot open output file /etc/bin/cmd/r.interception: No
such file or directory
collect2: ld returned 1 exit status
make: *** [/etc/bin/cmd/r.interception] Error 1
I see that my gmake53 contain the line INST_DIR=/home/grass/grass53
It compile correctly the code but the installation that fails....
I suppose that instead of /etc/bin/cmd/r.interception it should be
$INST_DIR/bin
In fact I can find it in
/home/mcannata/grass53_exp_2004_03_27/dist.i686-pc-linux-gnu/etc/bin/cmd/r.evapo.PM,
the problem is just in copying it in the /home/grass/grass53/bin directory?
Paul Kelly wrote:
>On Thu, 15 Apr 2004, Massimiliano Cannata wrote:
>>sorry, i run
>>ln -s /home/bin/gmake53 /usr/local/bin/gmake53
>>but also using /home/bin/gmake53 the output is always the same......
>Well yes because you are still running the wrong gmake53 (assuming the
>configure line you gave in your last message is correct). You said
>--bindir=/home so the correct version is /home/gmake53.
>If you did --bindir=/home/bin then it would be /home/bin/gmake53
>What does
>show... are there several copies of gmake53 on your system?
>The way I see it the gmake53 in /usr/local/bin (and perhaps /home/bin also)
>seems to be old and out of date and doesn't have the line
>INST_DIR=xxxx
>that should be there since 25th March when I made some improvements to the
>gmake script.
>Let me know how you get on.
>Paul
note: change my e-mail reference to massimiliano.cannata at supsi.ch
because the old one will be deleted soon.
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040416/e8a08087/attachment.html
