[GRASSLIST:3283] Re: Failure to make a Mask?
    Markus Neteler
    neteler at itc.it
    Tue Apr 27 04:57:19 EDT 2004
Phillip,
it seems that the underlying s.surf.rst (used in r.fillnulls)
has some problems with LatLong projection. Did you
use it in LatLong?
And: Which GRASS version are you using?
The author of s.surf.rst is working on it, probably
also r.fillnulls needs a modification).
Regards
 Markus Neteler
On Mon, Apr 26, 2004 at 01:20:47PM +0000, paallen at attglobal.net wrote:
> Hi all,
> I have been filling in the nulls of some vary
> large srtm3 dems with r.fillnulls.  I tried to
> select a few large areas, and r.fillnulls crapped
> out due to the area being to large.  A few times I
> ctr+c to break the program after I realized the
> area was too big.
> Now I have noticed that I cannot (nor can
> r.fillnulls) apply a MASK.  I can un-apply
> whatever mask is in use but when I try to apply my
> own mask a very quick error message flashes and
> disappears and the applied mask is named 'none'.
> What terrible things have I done to my location
> and mapset?  Is it possible to clean up and/or
> repair whatever I have done?
> Thanks,
> Phillip J. Allen
