[GRASSLIST:3309] Re: GRASS 5.0.3 problem
Thomas Adams Thomas.Adams at noaa.gov
Fri Apr 30 07:11:44 EDT 2004
Glynn,
I'll heed your advice. At this point would I be better off going to
GRASS 5.3 (which I understand is still under development) or just using
5.0.3?
Thanks for your help.
Regrads,
Tom
Glynn Clements wrote:
>Thomas Adams wrote:
>>I have been running GRASS 5.0.2 until recently with relatively few
>>problems. However, two days ago I decided to upgrade to GRASS 5.0.3 and
>>encountered the following problem:
>>[oper at dell5-tir data]$ grass5
>>Cleaning up temporary files.....
>>Starting GRASS ...
>>/usr/local/grass5/etc/set_data: /lib/i686/libc.so.6: version `GLIBC_2.3'
>>not found (required by /usr/local/grass5/etc/set_data)
>>Any thoughts what I can do? I've been trying to build glibc-2.3 but I
>>have not succeeded (I can not generate a make file even though the
>>'configure' seems to complete OK).
>Building GRASS from source is likely to be simpler (and less risky)
>than building (and installing) a newer version of glibc from source.
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040430/b8ef509e/attachment.html
