[GRASSLIST:4062] Re: how to create GUI in grass5.7
Michael Barton
michael.barton at asu.edu
Mon Aug 2 03:05:57 EDT 2004
This discussion is a bit baffling. What version do you have?
The current version of GRASS 5.7 normally opens with the display
manager (command d.m) active, and a complete TclTk menu system for all
GRASS commands.
If you have a current version and have somehow turned off the GUI, you
can restart it as Didit describes below or by starting with grass57
-tcltk. Typing tcltkgrass & from the GRASS xterm prompt while running
GRASS will start the GUI temporarily (i.e., for that session).
If you have an older version of GRASS 5.7 (e.g., early 2004 or before)
and want to add the current GUI, you can download and install it from
my website at <www.public.asu.edu/~cmbarton/grass.htm>. Note, however,
that this GUI contains menu entries for GRASS modules that have been
added since the pre-GUI version.
Hope this helps.
Michael
On Aug 1, 2004, at 10:01 PM, Multiple recipients of list wrote:
> If you always want to open up grass with a graphical interface, just
> change your
> .grassrc5 file with a unix text editor like pico. Change the line
> that says
> GRASS_GUI: text
> to
> GRASS_GUI: tcltk
> with grass 57 the file might be called .grassrc57
> Good luck,
> Ian
> Quoting Didit Ahendra <dee2t2001 at yahoo.com>:
>> hi all,
>> I use grass 5.7 with my vector data to make Geographical Information
>> System
>> about transportation.
>> A long this time I just use and type grass command on grass prompt to
>> operation my vector data.
>> I want ask you all, about GUI (Graphics User Interface) in grass.
>> I want to make a button in a windows that I can click to do some grass
>> command.
>> what should I do to make GUI in grass 5.7?
>> would you tell me how to make a button, please?
>> thank's for your help before.
>> regards,
>> Didit
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
