[GRASSLIST:4111] Re: nviz don't compile
Glynn Clements glynn.clements at virgin.net
Fri Aug 6 01:13:47 EDT 2004
Michele wrote:
> I compiled grass57 with the exp_2004_07_31 sources and nviz do not
> start giving the following error:
> Error: couldn't execute "nviz": no such file or directory
Then nviz failed to compile for some reason. You will need to examine
the output from "make" in order to determine the reason.
["nviz" itself is a script but, if the NVWISH2.2 executable fails to
compile, make will abort processing the visualization/nviz directory
without installing the nviz script.]
Glynn Clements <glynn.clements at virgin.net>
