[GRASSLIST:4136] Re: r.support
Markus Neteler neteler at itc.it
Mon Aug 9 03:45:36 EDT 2004
On Sun, Aug 08, 2004 at 10:13:13PM +0200, Martin May wrote:
> Hi!
> I am working with Grass 5.7.0.
> To fill some null-cells in a float-raster-heightmap I tried to utilize
> r.fillnulls. The script produces values far away from the surrounding
> values.
> So I looked into this script and found the command:
> v.surf.rst -v ...
do you mean
 r.to.vect -v
> My heightmap isn't cell so - it doesn't work. Might be because of high
> temperatures in my town but I remembered about a tool called r.support
> in older grass-versions, which generated the cell-headers.
Could you post the r.info output of your temperatures map?
Also the r.fillnulls command line you used?
> So I searched for this tool in the manuals and there are some dead links
> to it - it is not there.
Please indicate the dead links (then we can fix them).
> Can you give me a hint about how to solve the problem?
> Greetings
> Martin
Markus
