[GRASSLIST:4148] ./configure gcc problem
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Tue Aug 10 06:34:52 EDT 2004
hello,
this is probably not a GRASS problem but perhaps somebody encountered this
problem with GRASS already.
I tried to compile the GRASS 57 snapshot as well as the older 5.7.0 source,
but both processes were terminated with a gcc error. Previous attempts did
not result in such error prompts.
./configure --with-grass50=/home/misc/software/grass/grass53_exp_2004_08_07
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... no
configure: error: installation or configuration problem: C compiler cannot
create executables.
I upgraded some packages under debian and probably some dependencies caused
gcc to upgrade as well.
I checked gcc:
> apt-cache show gcc
Package: gcc
Priority: standard
Section: devel
Installed-Size: 28
Maintainer: Debian GCC maintainers <debian-gcc at lists.debian.org>
Architecture: i386
Source: gcc-defaults (1.17)
Version: 4:3.3.4-2
Provides: c-compiler
Depends: cpp (>= 4:3.3.4-2), gcc-3.3 (>= 1:3.3.4-1), cpp-3.3 (>= 1:3.3.4-1)
Recommends: libc-dev
Suggests: make, manpages-dev, autoconf, automake, libtool, flex, bison, gdb,
gcc-doc
Conflicts: gcc-doc (<< 1:2.95.3)
Filename: pool/main/g/gcc-defaults/gcc_3.3.4-2_i386.deb
MD5sum: 8137bb3b2add83c858090a125e071124
Description: The GNU C compiler
 This is the GNU C compiler, a fairly portable optimizing compiler for C.
 This is a dependency package providing the default GNU C compiler.
Package: gcc
Priority: standard
Section: devel
Installed-Size: 52
Architecture: i386
Source: gcc-defaults (0.21)
Version: 2:2.95.4-14
Depends: cpp (>= 2:2.95.4-14), gcc-2.95, cpp-2.95
gcc-2.95-doc
Filename: pool/main/g/gcc-defaults/gcc_2.95.4-14_i386.deb
MD5sum: ca2733b8228f1a47592714cbaa3be453
Description: The GNU C compiler.
 This is a dependency package providing the default GNU C compiler for
 Debian GNU/Linux systems (version 2.95.4 for architecture i386).
Task: c-dev
any ideas what might be wrong. otherwise I send a mail onto the debian ML.
cheers Martin
