[GRASSLIST:4177] Re: GRASS installation problem
Michael Barton
michael.barton at asu.edu
Thu Aug 12 02:35:08 EDT 2004
Cees,
I think you will have better luck with GRASS 5.3 or GRASS 5.7. A number of
problems have been corrected in these more up-to-date versions. You can get
them in binary form from my site and Rich Greenwood (links to Rich on my
site also). You should also install Rich¹s GDAL binaries to give you lots of
import/export options. And get the Spearfish demo data set for 5.3 and 5.7
to practice on. My site is <http://www.public.asu.edu/~cmbarton/grass.htm>.
Rich Greenwood¹s site is <http://www.greenwoodmap.com>. I hope this helps.
Michael Barton
On 8/11/04 2:31 AM, "van der Mark, C.J. <xs4all account via olvg>"
<cvdmark at xs4all.nl> wrote:
> Hello,
> I'm a newbie GRASS user and I have a problem with installing the package.
> I run WIN-XP (homeversion), NTFS, on a PIII 550Mhz, 512 Mb RAM
> Multiboot system Win98(C) / WinXP(D)
> Installed Cygwin according to the install-manual on the 5.0.3 download page
> Installed X11 completely
> Installed tcltc packages from the 5.0.3 download page, tcltk package of
> current Cygwin release was not installed.
> Installed GRASS 5.0.3 according to install manual.
> Started GRASS, textmode and filled-out the form about the project.
> Then GRASS started
> But that was it....when I use tcltkgrass& I get a bunch of errors
> Via mailinglist I got these commands to try:
> $ /usr/X11R6/bin/XWin.exe -multiwindow -clipboard &
> worked fine, bunch of text running by in the bash-shell
> (Cygwin/X Server appeared in the system tray)
> $ grass5
> text mode
> selected the project, esc, enter
> grass prompt appeared
> d.mon x1
> Then errors appeared again:
> Can't bind to socket; already in use?
> No socket to connect to for monitor <x1>.
> Problem selecting x1. Will try once more
> Whatever I try, it will not start.
> The last two weeks I have tried (and failed) 5 times installing the
> cygwin/grass5.0 system.
> I even tried to install the complete cygwin packages (except tcltk) with
> grass5.
> I then see a window starting up, but exiting with errors.
> Does anyone know this kind of problem and what to do to get it working
> properly?
> Best regards,
> Cees van der Mark,
> Amsterdam, The Netherlands
Michael Barton, Professor
School of Human Origins, Cultures, & Society
Arizona State University
Tempe, AZ 85287
Web - http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040811/ce1bfbdf/attachment.html
