[GRASSLIST:4181] Adding CATs back to output from v.buffer/v.distance in 5.7 on
Linux - Redhat
Craig Aumann
caumann at ualberta.ca
Fri Aug 13 19:32:45 EDT 2004
I'm having serious problems trying to add cats back to the output from
v.buffer so that I can link the buffered attributes back up to the
original attribute table for the original points objects. I think I'm
stuck after calling v.distance. I do hope there's an easy way to do
this.
Here's what I've done:
GRASS 5.7.0:~/grassalpac > v.category input=wellsselect option=report
FIELD 1:
type count min max
point 7 9202 67256
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 7 9202 67256
GRASS 5.7.0:~/grassalpac > v.category in=wellsselect field=1
option=print
9202
42724
57869
58276
62189
65873
67256
GRASS 5.7.0:~/grassalpac > v.buffer input=wellsselect output=wellstemp
type=point buffer=100
\WARNING: Vector 'wellstemp' already exists and will be overwritten.
Lines buffers ... 100%
Building parts of topology ...
Building topology ...
7 primitives registered
Topology was built.
Number of nodes : 6
Number of primitives: 7
Number of points : 0
Number of lines : 0
Number of boundaries: 7
Number of centroids : 0
Number of areas : -
Number of isles : -
Snapping boundaries ...
All vertices: 168
Registered points (unique coordinates): 138
Nodes marked as anchor : 138
Nodes marked to be snapped : 0
Snapped vertices : 0
New vertices : 0
Breaking boundaries ...
Intersections: 0
Removing duplicates ...
Duplicates: 1
Attaching islands ...
6 areas built 0%
6 isles built
Topology was built.
Number of nodes : 6
Number of lines : 0
Number of areas : 6
Number of isles : 6
Number of areas without centroid : 6
Attaching centroids ...
Topology was built.
Number of nodes : 12
Number of primitives: 13
Number of lines : 0
Number of centroids : 6
Number of areas : 6
Number of isles : 6
Rebuilding topology ...
12 primitives registered
6 areas built 0%
6 isles built
Topology was built.
Number of primitives: 12
Number of lines : 0
Number of boundaries: 6
Number of areas : 6
Number of isles : 6
DON'T UNDERSTAND WHY THERE ARE ONLY 6 AREAS - THE ORIGINAL POINTS
ARE DISTINCT AND DO NOT OVERLAP - EVEN WITH MUCH LARGER BUFFERS THAN I
AM USING.
GRASS 5.7.0:~/grassalpac > v.category input=wellstemp output=wellsbuf
option=add field=2 step=1
GRASS 5.7.0:~/grassalpac > v.category in=wellsbuf type=centroid
option=report
FIELD 1:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 6 1 1
area 0 0 0
all 6 1 1
FIELD 2:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 6 1 6
area 0 0 0
all 6 1 6
GRASS 5.7.0:~/grassalpac > v.distance -a from=wellsbuf
from_type=centroid from_field=2 \
> to=wellsselect to_type=point \
> max=2 upload=cat col=LINK_KEY table=wellsbuf_att
Statistics:
0 categories with more than 1 feature in 'from'
0 categories - no nearest feature found
7 distances calculated
7 records inserted
0 insert errors
## Wellsbuf_att looks like:
alpac_netdown=# select * from wellsbuf_att;
from_cat | link_key
1 | 9202
2 | 42724
2 | 57869
3 | 58276
4 | 62189
5 | 65873
6 | 67256
(7 rows)
GRASS 5.7.0:~/grassalpac > v.db.connect -o map=wellsbuf
table=wellsbuf_att key=from_cat field=2 \
> driver=pg database="dbname=alpac_netdown,user=caumann"
WARNING: The table <wellsbuf_att> is now part of vector map <wellsbuf>
and may be deleted or overwritten by GRASS modules.
NOW, WHAT IS THE v.category COMMAND THAT I NEED TO ISSUE TO GET LINK_KEY
FROM THE LINKED TABLE COPIED OVER INTO THE CAT FOR A GIVEN FIELD (1 OR
3). I JUST CAN'T FIGURE THIS OUT. ALL THE OPTIONS I TRY DON'T HAVE THE
DESIRED BEHAVIOR.
