[GRASSLIST:4190] Re:
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Mon Aug 16 11:31:41 EDT 2004
I have no idea if this is your problem or not, but you might want to try a
unix text editor like pico or vi. Just copy and paste your data from the
windows text editor into the unix on, then save that, then try to import. I
found that this solution often fixed weird errors for me.
Good luck,
Ian
On Aug 16, 2004, at 5:25 AM, Jan Bartholdy wrote:
I am having a serious problem to import site data from an ascii file:
The file:
0 0 0
0 1 0
0 2 0
0 7 0
, which is saved as a *.txt with the editor from Windows contains the
easting in the first, the northing in the second and a category in the third
column.
The current region in Grass is: N 11, S-1, W -1 and East 11. The resolution
is 0.125. I am using Grass 53 for Cygwin.
s.in.ascii gives the following error: segmentation fault (core dumped)
The stackdump is tho follow:
xception: STATUS_ACCESS_VIOLATION at eip=610AEB58
eax=00000010 ebx=00000000 ecx=00000001 edx=00000008 esi=1E4643F5
edi=1E4643FD
ebp=0022ECA0 esp=0022EC68
program=M:\cygwin\usr\local\grass53\etc\bin\cmd\s.in.ascii, pid 1620, thread
main
cs=001B ds=0023 es=0023 fs=0038 gs=0000 ss=0023
Stack trace:
Frame Function Args
0022ECA0 610AEB58 (100206A0, 610D5140, 00000007, 61095455)
0022ECE0 610564E8 (1E4643FD, 00000008, 0022EF60, 00402054)
0022ED00 610882AF (1E4643FD, 00000008, 00000000, 0022ED60)
0022EF60 0040257C (100201EC, 00000000, 00000000, 0022EFA8)
0022F070 00401673 (00000001, 616E451C, 100200A8, 0022F0C8)
0022F0B0 61005ED4 (0022F0C8, 00000000, 00000000, 00000000)
0022FF90 610060EB (00000000, 00000000, 00000000, 00000000)
End of stack trace
Thanks for the help, Jan
