[GRASSLIST:4192] Adding CATS to buffered lines (Grass5.7)
    Craig Aumann
    caumann at ualberta.ca
    Mon Aug 16 19:22:09 EDT 2004
The way I've cobbled CATs onto buffered lines is given below.
I have two questions:
- Is there a better way to do this?
- What is the appropriate tool to use for v.clean after I have patched
everything together?  The tool svtlx (listed in the man page for
v.patch) does not exist in v.clean.
I'm not that concerned about the intersections between the buffered
lines - they could be assigned to the CAT for any of the original
lines.
declare -i MYCOUNTER
MYCOUNTER=1
for MYCAT in 13 3 12 2;
do
  v.extract input=seismicselect output=seismicselecttemp \
      list=$MYCAT new=-1
## buffer it.
  v.buffer input=seismicselecttemp output=seistempbuf type=line buffer=3
  v.category input=seistempbuf output=seistempbuf2 type=centroid \
      option=add field=2 step=1
  v.category input=seistempbuf2 output=seistempbuf3 type=centroid \
      option=sum field=2 cat=-1
  v.category input=seistempbuf3 output=seistempbuf1 type=centroid \
      option=sum field=2 cat=$MYCAT
  if test "$MYCOUNTER" -eq 1; then
      let "MYCOUNTER=$MYCOUNTER+1"
      v.patch input=seistempbuf1 output=seisfintemp
  else
      v.patch input=seistempbuf1,seisfintemp output=seisfintemp2
      g.remove vect=seisfintemp
      g.copy vect=seisfintemp2,seisfintemp
  fi
done
v.category input=seisfintemp option=report
