[GRASSLIST:4198] Re: Adding CATS to buffered lines (Grass5.7)
Craig Aumann
caumann at ualberta.ca
Tue Aug 17 12:55:07 EDT 2004
How new? I'm running on Red Hat Enterprise 3.0.
[root at landscape installs]# rpm -q grass
grass-5.7.0-1
I've just looked at the online binaries, and I think I have the most
recent RPM installed.
Am I going to have to compile from source?
Cheers!
Craig
On Tue, 2004-08-17 at 10:38, Radim Blazek wrote:
> New option. v.overlay writes 3 categories, first is a new unique
> cat, the second is that from ainput and the third from binput;
> fields are in this order. 'ofield' can change output fields.
> With 'ofield=0,1,1' it will not write new unique cat
> and it will merge cats from ainput and binput
> into field 1 (i.e. two cats of the same field).
> This option was added exactly for what you are doing - patching
> of overlapping areas.
> Radim
> On Tuesday 17 August 2004 17:57, Craig Aumann wrote:
> > Thanks! That's certainly a bit cleaner.
> > I don't understand your v.overlay command, however. My version of
> > Grass5.7 doesn't have an ofield option. Similarly, I don't see why
> > field=1 should send things to the output - the only options I see are
> > afield and bfield.
> > A bit confused by what you mean!
> > Craig
> > > v.overlay -t ainput=seisbuf binput=seistempbuf2 output=seistempbuf3 \
> > > ofield=0,1,1 # input cats are written to output with
> > > field=1
