[GRASSLIST:4227] Re: DBMI-Postgres driver error
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Mon Aug 23 07:54:11 EDT 2004
hello Radim,
On Monday 23 August 2004 12:43, Radim Blazek wrote:
> GRASS cannot store passwords, if your DB requires a password
> add it to the database parameter. Try psql first.
The user is set up as a non-passwd user ('with password' is not used)
I can enter psql grass_test without being prompted for a password.
baliola at diomedea:~$ psql grass_test
Welcome to psql 7.4.3, the PostgreSQL interactive terminal.
Type:  \copyright for distribution terms
       \h for help with SQL commands
       \? for help on internal slash commands
       \g or terminate with semicolon to execute query
       \q to quit
grass_test=#
drop user baliola and created a new user with specifying a passwd:
create user baliola with password 'test';
however psql is not prompting for as passwd when entering the grass_test db.
exit postgres and superuser -- starting grass57 as baliola
db.connect driver=pg
database="host=localhost,dbname=grass_test,user=baliola,password=test"
driver:pg
database:host=localhost,dbname=grass_test,user=baliola,password=test
db.tables -p
DBMI-Postgres driver error:
Cannot connect to Postgres: FATAL:  IDENT authentication failed for user
"baliola"
I did it as well with ' around the password phrase -- same result.
Martin
> Radim
> On Monday 23 August 2004 11:55, Martin Wegmann wrote:
> > hello,
> > I did my first steps with postgresql and grass and ran into some
> > problems: First I created an user and set up a db ("grass_test")
> > starting grass (5.7.0):
> > database="host=localhost,dbname=grass_test,user=baliola"
> > I am not sure if "host=localhost" is correct. In all documents I read so
> > far, an IP address was specified but using 127.0.0.1 resulted in the same
> > error prompt. What do I enter when postgresql is running
> > locally?
> > If I proceed and do  'db.test grass_test' then db.test tells me that the
> > db must exist.
> > If I do db.test test1 I get:
> > cannot get user/password
> > and various Postgresql commands
> > Any idea how to solve that?
> > I am still searching for a tutorial introducing people to the postgresql
> > inside GRASS usage, so far I found
> > http://mpa.itc.it/markus/shortcourse/notes6.html  and
> > the GRASS 5.7 usage example document. any links are welcome.
> > regards, Martin
