[GRASSLIST:4234] Re: attribute table
Hamish
hamish_nospam at yahoo.com
Mon Aug 23 17:52:06 EDT 2004
> I am also doing on-screen digitizing.
> However, I would want to know how to see the attribute data table of
> the polygons I digitized. Also, how can I edit and add fields in the
> attribute table?
Vector data:
Try d.what.vect to view, or 'd.what.vect -e' to edit. If you can install
QGIS, this might be easier to work with. To view a .dbf database load into an
OpenOffice or use the 'dbview -bt' utility.
Add fields in v.digit [5.7] from settings->table.
Raster data: [5.0/5.3]
v.support
[5.7] ??
Hamish
