[GRASSLIST:4250] v.in.ogr problem
Craig Aumann
caumann at ualberta.ca
Wed Aug 25 16:03:18 EDT 2004
Running recent version of 5.7. The problem seems to occur while the
vectors are being cleaned. I have attached the shape files. I did
read this vector in fine with an earlier version of 5.7.
SHPFILE="utm_grd"
DBFFILE="utm_grid_fin"
GRASS 5.7.cvs:~/grassalpac/setupfiles > v.in.ogr -o dsn="$SHPDIR"
output=shutin layer="$SHPFILE"
Over-riding projection check.
Proceeding with import...
WARNING: The vector 'shutin' already exists and will be overwritten.
Layer: utm_grd
Building topology ...
1168 primitives registered
1168 areas built
1168 isles built
Topology was built.
Number of nodes : 1168
Number of primitives: 1168
Number of points : 0
Number of lines : 0
Number of boundaries: 1168
Number of centroids : 0
Number of areas : 1168
Number of isles : 1168
Number of areas without centroid : 1168
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 4858
All points (vertices): 6026
Registered points (unique coordinates): 4858
Points marked for break: 1168
Breaks: 0
Remove duplicates:
Duplicates: 0
Break boundaries:
Intersections: 6958
Remove duplicates:
Duplicates: 721
Clean boundaries at nodes:
Modifications: 231ERROR: Attempt to read dead line 13127
Type: application/x-compressed-tar
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040825/325cf2cb/myutm.tar.bin
