[GRASSLIST:4256] Re: ITCSpam: v.in.ogr problem
Radim Blazek
blazek at itc.it
Thu Aug 26 07:34:02 EDT 2004
It is a bug in v.in.ogr (Vect_clean_small_angles_at_nodes),
I don't have a chance to fix it until monday. For now, you can
use v.in.ogr with snap=0.1 (or other reasonable threshold).
Radim
On Wednesday 25 August 2004 22:03, Craig Aumann wrote:
> Running recent version of 5.7. The problem seems to occur while the
> vectors are being cleaned. I have attached the shape files. I did
> read this vector in fine with an earlier version of 5.7.
> SHPFILE="utm_grd"
> DBFFILE="utm_grid_fin"
> GRASS 5.7.cvs:~/grassalpac/setupfiles > v.in.ogr -o dsn="$SHPDIR"
> output=shutin layer="$SHPFILE"
> Over-riding projection check.
> Proceeding with import...
> WARNING: The vector 'shutin' already exists and will be overwritten.
> Layer: utm_grd
> Building topology ...
> 1168 primitives registered
> 1168 areas built
> 1168 isles built
> Topology was built.
> Number of nodes : 1168
> Number of primitives: 1168
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 1168
> Number of centroids : 0
> Number of areas : 1168
> Number of isles : 1168
> Number of areas without centroid : 1168
> WARNING: Cleaning polygons, result is not guaranteed!
> Topology was built.
> Number of lines : 0
> Number of areas : -
> Number of isles : -
> Break polygons:
> Registering points ... 4858
> All points (vertices): 6026
> Registered points (unique coordinates): 4858
> Points marked for break: 1168
> Breaks: 0
> Remove duplicates:
> Duplicates: 0
> Break boundaries:
> Intersections: 6958
> Remove duplicates:
> Duplicates: 721
> Clean boundaries at nodes:
> Modifications: 231ERROR: Attempt to read dead line 13127
