[GRASSLIST:4264] Re: Releasing GRASS modules
Michael Barton
michael.barton at asu.edu
Fri Aug 27 01:57:15 EDT 2004
Benjamin,
I am excited to hear about the predictive modeling modules you are
developing. This is an excellent use of GRASS for archaeology, as well as
other natural science fields that can use this.
I agree with Paul about encouraging you to write for 5.7. The raster format
for 5.3 and 5.7 are the same. There seems to be little needed to make a
raster module 5.7 'compliant'. And raster modules that work in 5.7 also work
in 5.3.
Vectors and sites are a different story of course. However, the linked
multi-attribute tables of GRASS 5.7 vectors make them much more flexible
than the 5.3 vector model. Vector points in 5.7 likewise have greater
potential than ascii sites in 5.3.
I am looking forward to seeing these modules.
Michael
On 8/26/04 4:18 PM, "Paul Kelly" <paul-grass at stjohnspoint.co.uk> wrote:
> On Thu, 26 Aug 2004, Benjamin Ducke wrote:
>> I would like to release some GPL'd GRASS 5.3 modules
>> for spatial predictvie modelling into
>> the GRASS community. My questions are:
>> 1. is there a way to set up a Gmakefile so that HTML
>> manpages are merged into the GRASS documentation index?
>> The way it is right now, the HTML pages get copied into
>> the user's documentation/html directory, but there are
>> no links from the main index.html file so that the user
>> is left to point his webbrowser to the files explicitly.
> No; this index is just maintained manually. Note that all the files in the
> html/html directory are converted into man pages during compilation so
> that you can read them with g.manual. This isn't done for 5.7 (although I
> wish it was), which just has html pages.
>> 2. once other people have tried and tested the modules
>> and find them useful, is it possible to include them
>> into the 5.3 CVS, so that people will not have to
>> download the source from my homepage and have to install
>> separately?
> There will be no new modules in the 5.3 CVS before the 5.4.0 release. Do
> the modules use any special features of 5.3 that mean they can't be used
> directly or easily ported to 5.7?
> Perhaps if things drag on for a long time, after the 5.4.0 release the
> modules could be added to the '5.5 CVS', but CVS write access to that is
> going to be closed so you would not be able to commit bugfixes. Better to
> add them to 5.7 I think.
> Paul
____________________
C. Michael Barton, Professor
School of Human Diversity and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
