[GRASSLIST:4269] Re: importing canadian dem -> dted data
Peter Sprague
peter_sprague at mac.com
Sun Aug 29 22:47:42 EDT 2004
Ian,
I am attempting to import DEMs of Columbia Valley, BC. The data is
.75' resolution, 1201X1201pts, ascii DTED data. I have successfully
imported some test data from US dems to MACDEM, but can't import into
GRASS. "file not available" with r.in.dted. With r.in.gdal, the error
code is "usr/lib/??.lib does not exist. Exported a PGM file from
MACDEM of dems with r.in.pgm - imported 100% as "test_dem". Nothing
shows up on x0 monitor.
The end result I'm working towards is:
tiled VRML of 3D terrain visualizations;
delivered via java as a PPGIS where citizens provide me with
georeferenced environmental impact data over the web;
analyze for regional cumulative environmental impacts.
Any help would be great,
Peter
On 29-Aug-04, at 6:52 PM, Ian Macmillan wrote:
> Hi there Peter, what type of data is GeoBase data? What are the error
> messages
> you get when trying to import? Also when you tried to test for bad
> data, you
> said it was "no go". Does this mean you couldn't import any data of
> any type?
> It is hard to answer your questions without this kind of information.
> I
> understand your frustration (been there myself), but try to be a
> little more
> explicit with your errors on the mailing list, and the answers you get
> might be
> more helpful.
> Cheers,
> Ian
> Quoting Peter Sprague <peter_sprague at mac.com>:
>> Hi,
>> Looking for some guidance on importing Canadian GeoBase data into
>> grass. I'm new to grass, using 5.3 ported to OSX, tried r.in.gdal &
>> r.in.dted to no avail. Read manuals, etc. too much over the last
>> week.
>> Tried US data to test for bad data, no go. I must be missing
>> something!?
>> Peter
> Ian MacMillan
> Geological Sciences-UCSB
> "insert witticism here"
