[GRASSLIST:4273] RE: r.resamp.rst
Javier A. Yebrin
javier.yebrin at ing.unitn.it
Mon Aug 30 05:55:30 EDT 2004
Hello, I had the same problem. The module r.resamp.rst is not available in the GRASS 5.7.0 sources.
I had to download and compile GRASS 5.3.0 where this module does exist. I don't know if it is included
in the latest CVS version of 5.7, but even so, you need to download 5.3.0 first.
Hope this helps.
Javier Yebrin
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]On
> Behalf Of Sabine Grabner
> Sent: Monday, August 30, 2004 10:37 AM
> To: GRASS
> Subject: [GRASSLIST:4271] r.resamp.rst
> hello, in my grass 5.7 distribution (self compilation from 17th
> of june) i
> miss the r.resamp.rst module. i have read some letters dated by
> the end of
> april which says "So today I have experimentally re-enabled
> compilation of
> r.resamp.rst as it may be all right now. ".
> how do i get the required module.
> thanx, sabine
