[GRASSLIST:4276] RE: r.resamp.rst
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Aug 30 15:04:49 EDT 2004
On Mon, 30 Aug 2004, Javier A. Yebrin wrote:
> Hello, I had the same problem. The module r.resamp.rst is not available in the GRASS 5.7.0 sources.
> I had to download and compile GRASS 5.3.0 where this module does exist. I don't know if it is included
> in the latest CVS version of 5.7,
It is, since 16th July 2004.
> but even so, you need to download 5.3.0 first.
That is not quite correct---it is the 5.3 CVS HEAD you need (5.3.0 is
several months old and not compatible with the latest 5.7 CVS).
Paul
