[GRASSLIST:5029] problem with v.patch
Allard, Yannick (EXP)
yannick.allard at lmco.com
Thu Dec 2 15:07:28 EST 2004
Hi everyone,
I have some problem with v.patch. First I import vector file (areas) using v.in.ogr. When I display them everything is ok and the area is clearly shown. When using v.patch to create one vector file, the areas are not kept properly and several line are erased (incorrect boundaries) and the only area that are shown are the areas in the middle of the object (it is a runway and only the grass between the actual runway are kept as areas...).
What am I doing wrong?
Thanks in advance
Yannick
Yannick Allard
Ph.D student, Universite de Sherbrooke
