[GRASSLIST:5054] Re: r.plane problem
    Markus Neteler
    neteler at itc.it
    Sun Dec  5 08:59:12 EST 2004
On Fri, Dec 03, 2004 at 01:38:59PM +0100, ivan marchesini wrote:
> Thank you Markus....
> I have seen that the problem was the region...
> because I had float value and the script needs integer.....
> simply changing float value to integer all is correctly working!!!!!
The script also works with floating point coordinates (for me).
Please report the detailed log of sh -x.
Markus
> thank  you
> Il giorno ven, 03-12-2004 alle 11:30 +0100, Markus Neteler ha scritto:
> > On Thu, Dec 02, 2004 at 06:35:37PM +0100, ivan marchesini wrote:
> > > Dear users...
> > > I'm trying to use r.plane within grass57...
> > > the region settings are:
> > > __________________________
> > > zone:       0
> > > datum:      rome40
> > > ellipsoid:  international
> > > north:      4745617.74
> > > south:      4743280.26
> > > west:       2350445.5
> > > east:       2355261.01
> > > nsres:      1.72
> > > ewres:      1.61
> > > rows:       1359
> > > cols:       2991
> > > ___________________________
> > > I use this command:
> > > ______________________________________________________________
> > > r.plane dip=30 az=100 ea=2355000 no=4745000 el=100 name=plane
> > > and I obtain:
> > > ____________________________________________________________________
> > > /usr/local/grass-5.7.cvs/scripts/r.plane: line 112: test: 2355261.01:
> > > integer expression expected
> > > Sorry, point must be within current region
> > > Current region:
> > > west: 2350445.5 east: 2355261.01
> > > _____________________________________________________________________
> > > do you know which is the problem???
> > > thank you
> > I tried with Gauss-Boaga Fuso Ovest,
> > works fine.
> > To debug this shell script, simply edit
> > and add -x to the top line:
> >  #!/bin/sh -x
> > Then re-run and it will display all steps. From that you
> > may understand what's wrong (and report or send the fix).
> > Thanks
> >  Markus
> ivan marchesini <marchesini at unipg.it>
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
