[GRASSLIST:5042] Re: r.plane problem
    ivan marchesini
    marchesini at unipg.it
    Fri Dec  3 07:38:59 EST 2004
Thank you Markus....
I have seen that the problem was the region...
because I had float value and the script needs integer.....
simply changing float value to integer all is correctly working!!!!!
thank  you
Il giorno ven, 03-12-2004 alle 11:30 +0100, Markus Neteler ha scritto:
> On Thu, Dec 02, 2004 at 06:35:37PM +0100, ivan marchesini wrote:
> > Dear users...
> > I'm trying to use r.plane within grass57...
> > the region settings are:
> > __________________________
> > zone:       0
> > datum:      rome40
> > ellipsoid:  international
> > north:      4745617.74
> > south:      4743280.26
> > west:       2350445.5
> > east:       2355261.01
> > nsres:      1.72
> > ewres:      1.61
> > rows:       1359
> > cols:       2991
> > ___________________________
> > I use this command:
> > ______________________________________________________________
> > r.plane dip=30 az=100 ea=2355000 no=4745000 el=100 name=plane
> > and I obtain:
> > ____________________________________________________________________
> > /usr/local/grass-5.7.cvs/scripts/r.plane: line 112: test: 2355261.01:
> > integer expression expected
> > Sorry, point must be within current region
> > Current region:
> > west: 2350445.5 east: 2355261.01
> > _____________________________________________________________________
> > do you know which is the problem???
> > thank you
> I tried with Gauss-Boaga Fuso Ovest,
> works fine.
> To debug this shell script, simply edit
> and add -x to the top line:
>  #!/bin/sh -x
> Then re-run and it will display all steps. From that you
> may understand what's wrong (and report or send the fix).
> Thanks
>  Markus
ivan marchesini <marchesini at unipg.it>
