[GRASSLIST:5032] vector lines to area?
Allard, Yannick (EXP) yannick.allard at lmco.com
Thu Dec 2 19:00:18 EST 2004
Hi everyone,
I have a porblem concerning the transformation of lines into area. I have .e00 files which I have converted with avcimport. These vector files are only lines even if some of them should define an area (there is no PAT in the e00 file, only AAT). I've tried importing the vector lines as area boundaries but it dont work quite well, some area are not showing up and some other that shouldn't be areas but holes are created. Is there an easy way to transform those lines which are defining an area into a real area so I could build a raster map with these area showing up? I've tried v.digit and selecting an centroid. However, for some area with holes the holes are still defined as areas (if I import the lines as area boundaries) or the lines are not defined as boundaries so I've got a centroid outside an area (is there a way to change the line into a boundary other than v.type, using v.type transform the lines as boundaries for 2 areas, which is not my case).
I'm using Grass 5.7.0
Thanks in advance, best regards
Yannick
