[GRASSLIST:5040] Re: db.login
Radim Blazek
blazek at itc.it
Fri Dec 3 06:01:18 EST 2004
Leonardo Lami wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> After the new command db.login and the remotion of v.database I have some
> problem with the relocation of the table when I import vectors (like shapes)
> in GRASS.
> Grass put the table in the database setted in the options GV_* of file VAR
> placed in the working mapset.
> I see that the command db.connect change the DB_* options but not the GV_*
> options.
> How can I change the GV_* options and what about the function of the DB_*
> options?
> Thanks of all
> Leonardo
GV_* are not used, vector tables are stored in database defined by DB_*
(db.connect).
> About overwrite protection I think that it is very important to have a flag
> to avoid delete the tables linked to a vector when I delete the vector. What
> do you think about it?
Almost impossible to add this flag to all modules. Why do you need that?
Cannot you db.copy the table?
Radim
