[GRASSLIST:5045] Re: mms - prms
edgar at hwr.arizona.edu edgar at hwr.arizona.edu
Fri Dec 3 10:55:56 EST 2004
I installed the 5.7 binaries. Do I have to reinstall compiling the source or
just recompile the already installed? If the last one, how can I recompile?
Thanks for your answer,
Edgar
Quoting Markus Neteler <neteler at itc.it>:
> On Thu, Dec 02, 2004 at 02:18:41PM -0700, edgar at hwr.arizona.edu wrote:
> > All,
> > I installed the latest GRASS version on red-hat-linux. I also needed to
> install
> > the hydro model MMS. MMS is looking for the GRASS library libgis.a but it
> > doesn't seem to exist anywhere on my system. Why is not there? How can I
> install it?
> Did you install GRASS 5.7? Compiled yourself?
> By default GRASS 5.4 and 5.7 are compiled with shared libraries (.so
> extension)
> which minimized the package size.
> However, MMS (URL?) wants the statically compiled libgis.a.
> An option might be (depending on which GRASS version MMS is based on) to
> recompile (only) lib/gis/ as static library.
> Markus
