[GRASSLIST:5048] Re: mms - prms
    Markus Neteler
    neteler at itc.it
    Fri Dec  3 12:02:43 EST 2004
Edgar,
compilation of GRASS requires the GRASS (5.7) source code.
You can grab it here:
http://grass.itc.it/download.html#g57
-> 5.7.0 (getting old these days)
-> CVS snapshot
-> CVS
It comes with an INSTALL file.
The source code directories (5.7.0 / snapshot) contain
subdirectories with examples how to run 'configure'
on various platforms (further donations welcome).
The file REQUIREMENTS.html explains the needed extra libraries
such as GDAL, PROJ etc.
Hope this helps
 Markus
On Fri, Dec 03, 2004 at 08:55:56AM -0700, edgar at hwr.arizona.edu wrote:
> I installed the 5.7 binaries. Do I have to reinstall compiling the source or
> just recompile the already installed? If the last one, how can I recompile?
> Thanks for your answer,
> Edgar
> Quoting Markus Neteler <neteler at itc.it>:
> > On Thu, Dec 02, 2004 at 02:18:41PM -0700, edgar at hwr.arizona.edu wrote:
> > > All,
> > > I installed the latest GRASS version on red-hat-linux. I also needed to
> > install
> > > the hydro model MMS. MMS is looking for the GRASS library libgis.a but it
> > > doesn't seem to exist anywhere on my system. Why is not there? How can I
> > install it?
> > Did you install GRASS 5.7? Compiled yourself?
> > By default GRASS 5.4 and 5.7 are compiled with shared libraries (.so
> > extension)
> > which minimized the package size.
> > However, MMS (URL?) wants the statically compiled libgis.a.
> > An option might be (depending on which GRASS version MMS is based on) to
> > recompile (only) lib/gis/ as static library.
> > Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
