[GRASSLIST:5056] Re: vector lines to area?
David Mahoney
mahoneyd at unbc.ca
Sun Dec 5 15:16:50 EST 2004
It sounds like you are trying to build "donut" areas, with an internal
isle clipped out. The only way I have found so far to do this is to
parse the output from v.build option=dump to identify the island
polygons, update the attribute table with this information, and then
run v.extract to select only the non-isle polygons. It would be nice if
v.category had a option to not label holes in a larger polygon.
David
On Thursday, December 2, 2004, at 04:00 PM, Allard, Yannick (EXP) wrote:
> Hi everyone,
> I have a porblem concerning the transformation of lines into area. I
> have .e00 files which I have converted with avcimport. These vector
> files are only lines even if some of them should define an area (there
> is no PAT in the e00 file, only AAT). I've tried importing the vector
> lines as area boundaries but it dont work quite well, some area are
> not showing up and some other that shouldn't be areas but holes are
> created. Is there an easy way to transform those lines which are
> defining an area into a real area so I could build a raster map with
> these area showing up? I've tried v.digit and selecting an centroid.
> However, for some area with holes the holes are still defined as areas
> (if I import the lines as area boundaries) or the lines are not
> defined as boundaries so I've got a centroid outside an area (is there
> a way to change the line into a boundary other than v.type, using
> v.type transform the lines as boundaries for 2 areas, which is not my
> case).
> I'm using Grass 5.7.0
> Thanks in advance, best regards
> Yannick
