[GRASSLIST:5067] Re: Width of geogrid lines in ps.map
Hamish
hamish_nospam at yahoo.com
Mon Dec 6 19:12:04 EST 2004
> Is is possible to control the width of the lines that the geogrid
> function draws when using ps.map? I am converting the ps.map
> generated postscript file to pdf via ps2pdf and then printing. The
> printed geogrid lines are extremely thin and hardly noticeable.
no, but it wouldn't be too hard for someone to add.
(copy code from 'vlines width #')
If you are keen you could try editing the postscript file directly in a
text editor. (search towards the very bottom for the coordinate value)
add line width with a line like
2.00000000 W
after the lines starting with "F" around there.
? worth a shot.
or try changing the color from grey to black.
I found which printer you used made a big difference; lasers being hard
to see the lines, ink jets easy.
Hamish
