[GRASSLIST:5069] Re: Width of geogrid lines in ps.map
Brent Crittenden
brent.crittenden at hasletwireless.net
Mon Dec 6 23:56:47 EST 2004
Hamish,
Thanks for reply, and I apologize for the double post. Newbie.
Good news and bad news. Good news is I successfully hacked my first
postscript file and made the grid lines wider! Bad news is that is
appears that the raster file portion of the postscript file was some
kind of binary that was blasted when I saved the postscript file as
text. The resulting postscript file still converted to pdf, but all
that was left really nice, width-controlled lines.
I echo your request for "someone" to add line width control to the
geogrid function in ps.map.
Brent
Hamish wrote:
> no, but it wouldn't be too hard for someone to add.
> (copy code from 'vlines width #')
> If you are keen you could try editing the postscript file directly in a
> text editor. (search towards the very bottom for the coordinate value)
> add line width with a line like
> 2.00000000 W
> after the lines starting with "F" around there.
> ? worth a shot.
> or try changing the color from grey to black.
> I found which printer you used made a big difference; lasers being hard
> to see the lines, ink jets easy.
> Hamish
