[GRASSLIST:5145] osx 5.7 startup woes, etc.
Ian MacMillan ian_macmillan at umail.ucsb.edu
Mon Dec 13 18:39:13 EST 2004
	Subject: 	osx startup woes and r.line
	Date: 	December 13, 2004 3:37:56 PM PST
	To: 	  grasslist at baylor.edu
Hi all, I have a weird error coming up when starting up grass5.7 from
Lorenzo Moretti's packages.  I just downloaded 5.4 and the most updated
5.7 today.  Somehow the display manager chokes on startup.  I get the
original splash screen for about half a second then this error follows:
GRASS 5.7.0:~ > Error in startup script: dyld: ps.map version mismatch
for library: /usr/local/grasslib/lib/libgdal.1.dylib (compatibility
version of user: 7.0.0 greater than library's version: 4.0.0)
     while executing
"exec ps.map -p"
     (procedure "DmPrint::init" line 14)
     invoked from within
"DmPrint::init"
     (procedure "main" line 27)
     invoked from within
"main $argc $argv"
     (file
"/Applications/Grass/grass57.app/Contents/Resources/grass-5.7.0/etc/dm/
d.m.tcl" line 773)
Anybody else run into this?
Also I can't find r.line anywhere, has it been changed into something
else?  I looked in the mailing lists, but as you can't enter periods
(.) in your search, it proved fruitless.
Thanks for any help y'all might have,
-Ian
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20041213/3806a30c/attachment.bin
