[GRASSLIST:2434] Re: r.poly - linear features
francesco.pirotti at unipd.it
Mon Feb 2 06:21:42 EST 2004
Did you try r.line ? It creates vectors from thinned linear features (thinned
with r.thin). The command is under "raster->Extract vector map" whereas r.thin
is "raster->analysemap->neighborhoos tools"
Hope it helps
Francesco
Scrive javier garcia - CEBAS <rn001 at cebas.csic.es>:
> Hi all;
> I've got a set of basins created with r.watershed and the corresponding
> streams raster map. And I would like to know if it is possible to
> convert
> these two maps into GRASS vector files.
> I've seen that the basins can be converted and treated with v.digit to
> correct the errors (the direct result is not very clean), but I can't
> find
> the way to transform the streams to linear features; the resulting file
> always appears as areas around the borders of the lines of stream cells.
> Thanks for your advise.
> Best wishes,
This mail sent through IMP: webmail.unipd.it
