[GRASSLIST:2460] Re: [grASSLIST:2447] Re: 5.7 vector attributes connection
Radim Blazek blazek at itc.it
Wed Feb 4 04:39:23 EST 2004
On Tuesday 03 February 2004 22:49, francesco.pirotti at unipd.it wrote:
> Nope, window yes, but no "Submit" button. (I used to get it before... but
> now now, no way)
> Also happens that when I digitize I do not get the submit button; only
> default values (0) and not editable...
> mmmmmhhhhh....
> I will try to fix it!  Let you know if I manage.
The form is HTML displayed in simple HTML browser and can be generated
(F_generate) either as text (F_VIEW) or HTML form (F_EDIT).
F_VIEW is used for vectors which are not in current mapset.
Radim
