[GRASSLIST:2483] Re: 5.7 build error after cvs today
Glynn Clements glynn.clements at virgin.net
Thu Feb 5 16:16:09 EST 2004
Kirk R. Wythers wrote:
> I am getting a build error on OS X
> Here is the error. Anyone recognize it?
> gcc -L/usr/X11R6/lib -L/sw/lib
> -L/Users/kirkw/grass5_dev/grass57_exp_2004_01_03/dist.powerpc-apple-
> darwin7.2.0/lib   -o
> darwin7.2.0/etc/bin/cmd/r.series OBJ.powerpc-apple-darwin7.2.0/c_ave.o
> OBJ.powerpc-apple-darwin7.2.0/c_divr.o
> OBJ.powerpc-apple-darwin7.2.0/c_max.o
> OBJ.powerpc-apple-darwin7.2.0/c_median.o
> OBJ.powerpc-apple-darwin7.2.0/c_min.o
> OBJ.powerpc-apple-darwin7.2.0/c_mode.o
> OBJ.powerpc-apple-darwin7.2.0/c_reg.o
> OBJ.powerpc-apple-darwin7.2.0/c_stddev.o
> OBJ.powerpc-apple-darwin7.2.0/c_sum.o
> OBJ.powerpc-apple-darwin7.2.0/c_var.o
> OBJ.powerpc-apple-darwin7.2.0/main.o
> OBJ.powerpc-apple-darwin7.2.0/sort_cell.o -lgrass_gis -lgrass_datetime
> -lintl  -lz
> ld: Undefined symbols:
> _c_count
> make[2]: ***
> [/Users/kirkw/grass5_dev/grass57_exp_2004_01_03/dist.powerpc-apple-
> darwin7.2.0/etc/bin/cmd/r.series] Error 1
I suspect that you forgot to run "make mix" for 5.7 after running
"cvs update" for 5.3.
A recent update to r.series added "method=count", which is implemented
in c_count.c. A "cvs update" will have added this file, and will have
modified main.c to require it, but it won't appear in 5.7 until you
run "make mix" again.
Glynn Clements <glynn.clements at virgin.net>
