[GRASSLIST:2485] Re: 5.7 build error after cvs today
Kirk R. Wythers kwythers at umn.edu
Thu Feb 5 16:30:49 EST 2004
argggggg.... you are right of course Glen.
On Feb 5, 2004, at 3:16 PM, Glynn Clements wrote:
> Kirk R. Wythers wrote:
>> I am getting a build error on OS X
>> Here is the error. Anyone recognize it?
>> gcc -L/usr/X11R6/lib -L/sw/lib
>> -L/Users/kirkw/grass5_dev/grass57_exp_2004_01_03/dist.powerpc-apple-
>> darwin7.2.0/lib   -o
>> darwin7.2.0/etc/bin/cmd/r.series OBJ.powerpc-apple-darwin7.2.0/c_ave.o
>> OBJ.powerpc-apple-darwin7.2.0/c_divr.o
>> OBJ.powerpc-apple-darwin7.2.0/c_max.o
>> OBJ.powerpc-apple-darwin7.2.0/c_median.o
>> OBJ.powerpc-apple-darwin7.2.0/c_min.o
>> OBJ.powerpc-apple-darwin7.2.0/c_mode.o
>> OBJ.powerpc-apple-darwin7.2.0/c_reg.o
>> OBJ.powerpc-apple-darwin7.2.0/c_stddev.o
>> OBJ.powerpc-apple-darwin7.2.0/c_sum.o
>> OBJ.powerpc-apple-darwin7.2.0/c_var.o
>> OBJ.powerpc-apple-darwin7.2.0/main.o
>> OBJ.powerpc-apple-darwin7.2.0/sort_cell.o -lgrass_gis -lgrass_datetime
>> -lintl  -lz
>> ld: Undefined symbols:
>> _c_count
>> make[2]: ***
>> [/Users/kirkw/grass5_dev/grass57_exp_2004_01_03/dist.powerpc-apple-
>> darwin7.2.0/etc/bin/cmd/r.series] Error 1
> I suspect that you forgot to run "make mix" for 5.7 after running
> "cvs update" for 5.3.
> A recent update to r.series added "method=count", which is implemented
> in c_count.c. A "cvs update" will have added this file, and will have
> modified main.c to require it, but it won't appear in 5.7 until you
> run "make mix" again.
> Glynn Clements <glynn.clements at virgin.net>
Kirk R. Wythers	                                     tel: 612.625.2261
Dept. of Forest Resources                 fax: 612.625.5212
University of Minnesota      email: kwythers at umn.edu
