[GRASSLIST:2487] g.mremove
Kirk R. Wythers kwythers at umn.edu
Thu Feb 5 19:58:56 EST 2004
How does one use g.mremove. I have recompiled 5.3 and 5.7 after cvs up
-dP today, and thought that its use and syntax were similar to
g.remove. However, I am getting a "command not found" error when I
attempt to run is from the command line (g.mremove -help yields nothing
as well). Is g.mremove something separate or require some kind of
compile option?
Thanks,
Kikrk
